Solid.BySweep operation failed. Unable to update solid bysweep: SWEEP_FACES_INTERSECT -- A face intersects with another face in the sweep body
I am getting this error when testing with curve walls. I did the same Solid.BySweep with straight walls and not problem. But With this Curve walls have errors. Any thoughts about possible causes?
Sounds similar to this, i’m sorry i can’t help you further. i’m MEP and not normally dealing with solids and sweeps.
the error below is different but that might be a version change thing, it sounds like the same thing.
