Solid.Centroid Returns Point at Origin
Hi all!
So whenever I perform Solid.Centroid on a list of Solids (Masses) imported from Revit, Dynamo returns the origin as centroid for some of them (see highlighted element in the screenshot below).
Dynamo screenshot:
Revit screenshot:
Attached is:
I played a bit with your files, but I couldn’t find a proper solution.
Things I found:
  • It returns the origin only, if the X value is positive. That’s why two of them shows up correctly, the other ones don’t. If I move the failing masses to the other side of the origin they show up correctly. I tried with spheres in a generic model family, the result is the same. At some positions it returns a null value.
  • I replaced the spheres with cubes and it showed the correct centroids, so the main bug is that they are spheres, and centroid calculation fails on them for some reason.
  • I could also reproduce a similar bug in a new empty file, spheres sometimes add null values even with mass or generic model spheres. Cubes never fail.
I guess it’s a bug in the centroid calculation of dynamo.
A workaround would be to use the Element.Getlocation node, it doesn’t fail, and extracts the same coordinates, if you have to use spheres.
Thank you very much for taking the time! I will use Element.Getlocation then. It is odd though that the centroid calc. fails on those cases.
Got the same bug…
Try with Code Block t1 = Autodesk.Solid.Centroid(solid1)
doesn’t seem to work either…
you’re trying like this
yep, exactly, im trying to do that. Get the centroid of an intersection.
Try like this
So I found out, the “Geometry Scaling” set to “extra large” or “large” causes this bug…
