Hello, I have a problem with Solid.ByLoft node, the results from dynamo do not appear in Revit, all what I get are those “blue lines”. I have already tried reopening and running via dynamo player, didnt work.
What you see is a dynamo object preview inside Revit. If you want that to “exist” inside revit as object, you can use the ImportInstance.ByGeometry.
It works, thanks a lot.
