Helo there, I been using dynamo for some time now, and I have used the “Solid.byloft” node, and in Dynamo the solid appears but in the revit model it appears as ghosted, I cannot select it or have properties of it, how can I change this solid to an actual solid that is selectable in revit.
It is not an actual solid in Revit, it’s just a preview. It seems as if you’re in a conceptual environment, so maybe you can use the Spring.Form.ByGeomtery node from the spring nodes package.
cheer mate, that did the trick
