Solid.byLoft Partially working
Hi All,
I’m trying to loft multiple cross sections to ultimately create one solid.
From the points on a segmented line, I’m able to create the cross sections. When I try to loft them, there’s an inconsistency in the loft action.
The solid I’m trying to create is part of a wall, I’m able to create other sections of the wall without a problem.
Anybody encoutered the same problem when using the Solid.byLoft node? Perhaps someone found a solutions or knows what the problem is…
Thanks in advance!
I’ve added my graph and the cad source file from which I create the cross sections.
Tunnelwand buitenwand Geometrie master.dyn (43.8 KB)
Geometrie Rechterbuis buitenwand 3.dwg (492.2 KB)
Try the loft by rails node as one possible fix.
@jacob.small
Thanks for your reply.
This might work, but this one isn’t really suitable for me since all the cross sections are different…
I likely have the wrong node name but you can thread multiple cross sections along a rail with the node I’m thinking of. I’m off on a day trip to a museum so I won’t be able to check (my international data is too slow so it won’t load the dictionary for me - it times out) but I’ll try to find it when I get wifi later tonight.
@jacob.small
I understand. Perhaps you mean one of these?Solidbyrails
@jacob.small
I’ve tried Solid.Byloft using guideCurves. This gives met the following result:
The result is sort of a hollow tube… Any ideas?
Can you post your dyn and source files for me to recreate this issue? Making a dataset that replicates your problem proved to be problematic (though it felt like it should be so simple - hard to recreate a failure unless you know why it’s failing).
Sure, here you go:
Tunnelwand buitenwand Geometrie master guidecurves.dyn (46.9 KB)
Geometrie Rechterbuis buitenwand 5.dwg (462.6 KB)
Geometrie Rechterbuis buitenwand 2.dwg (466.0 KB)
I’ve included different parts of the wall as a dwg file.
@jacob.small
Had any luck yet?
No was away from my cpu all weekend so I haven’t tried yet. I’ll check later today if my backlog feom a week of vacation isn’t too bad.
Now I ran the graph in Civil 3D and not sure if you fixed it but this looks good to me after I added Select Objects node
I cleaned up your graph and it look really nice, I will use your graph to test out my own workflow.
Tunnelwand buitenwand Geometrie master guidecurves ver 2.dyn (115.4 KB)
