I’m trying to create some solids by lofting some cross sections, but unfortunately I get an error:
‘Warning: Solid.ByLoft operation failed. Unable to loft! : NOT_ALL_SECTIONS_MEET – Some but not all sections meet.’
I don’t know if this is the solution, but have you tried putting a transpose node between the “List.Create” and the “Solid.ByLoft” Nodes? As far as I understand, you will then get 14 solids from the current selection, which you can then (maybe) join to a single solid
