Surface.ByLoft problem
I am new to the dynamo. I am trying to create surface by loft using a line and sin curve Unfortunately I was stuck with an error "Warning: Surface.ByLoft operation failed. Unable to loft!: ACIS_EXCEPTION_ACCESS_VIOLATION – Access violation " can someone help me where I went wrong.
Thank you
hi
try to use NurbSurface by points instead
Thank you for suggestion. Actually i want to know why can’t it create a loft here. As per my understanding this node requires two cross sections to create a loft accordingly i have provided two cross sections here. so i just want to know why cant it produce surface between two cross sections
ok,
the problem is in your sequence in the first codeblock {0…900…30}
use it without brakets
0…900…30 like this
or use Flatten node
because with braket it will put your sequence in sublist,
