Sloped Glazing alignment help
Ok I have a sloped glazing and a ceiling that the offsets are different. is there a way to select the ceiling grid and align the sloped glazing to that grid? for this example the offsets are -5 1/2" Not trying to get a handout without trying just want to know if it is possible?
this is a continuation of a previous task
I think you need to set layout rules of grids to Fixed Distance first, not Fixed Numbers.(so each size of ceiling panel won’t be changed after offset)
Then get desired x,y coordinates in the glazing profile, apply them to each offset. I think it can be done using Dynamo.
