Hello everyone!
I can’t figure out what is wrong with this simple node that should read a sheet from an excel file.
I tested both with string and code block. File path and sheetname are correct!
Using Dynamo 0.8.1.817
Regards
//Shahrokh
Hello everyone!
Regards
//Shahrokh
Throw a “File.FromPath” node in there and you should be good to go.
Thank you !
It worked.
However I had seen examples on the net that the wire goes out directly from File Path to Excel.ReadFromFile.
Any way. Appreciate your reply.
Regards
//Shahrokh
