hi i created new dynamo file
i used “excel .read from file” to read code from excel
i used this node before and it was warking , i dont no why today it isn’t working in this new dynamo
Hello. Please include either a picture or the actual dynamo file and/or excel file. We can’t just magically tell you what is wrong without any information other than it is not working. What Dynamo version were you using before and what now?
There is also this page which gives info on how to best ask for help here.
thank you
1st problem is solved
but i have another problem ,everything seems fine except “set parameter by name” as attached snap shot
What is the error you are getting? Can you confirm your element inputs are in fact elements?
It seems like you might be trying to set type parameters. Are your input elements types or family instances?
