Hello, I am trying to get my head around how to get type parameters out of families in dynamo, im sue it is very simple but i cant get it to work.
Can someone help ? i want to get the “W” type parameter out of columns
Column Parameter.dyn (5.6 KB)
Using the built in nodes for “GetParameterValueByName” will get you only the Instance parameters.
Clockwork has a great node called “Element.Type” which you can connect before the above node which will look for Type parameters instead. See image below
You already have them in a list in that watch node on the top left of your image. You dont need to use the other methods in your graph
apologies, it was just a general question on how to grab the values from a list that is not in numerical order
Ah okay, you might be able to use one of the “Search for” or “contains” nodes but im not sure.
