Hello Community!
Easy question. I want to reset override any time I want, ideally with a true/false option in Dynamo Player.
I tried couple of stuff with if statement but does not work. Any ideas?
Hi @el.kik
Which boolean are you looking to reset element? True to Reset or False to Reset?
I will set the Boolean as Dynamo Player Input and when is True the Override shal be true and vice verca
Add Elements to True Input, List.Empty to False and Boolean node to Test. That will allow you to switch on/off.
Like @Brendan_Cassidy showed.
may i ask which package is the View.ResetElementOverrides came from?
is it the same with Element.ResetOverridesInView of the Clockwork package?
Coz i tried with Element.ResetOverridesInView it does not work
EDIT :
Tried updating the clockwork. Using View.ResetElementOverrides now still not working on my side…
Erase completely Clockwork and download from packages the Clockwork for Dynamo 2.x the latest newest version! As you can see you find this node in Clockwork.
Moreover, substitute you last node on the right Element.Reset… with View.ResetElementOverrides (after you donwload the right Clockwork and keep the lacing as you have it) and I would say you change also the fill pattern to “Solid”. Sometimes the elements are highlighted but due to bad “hatching” you cannot see it.
Let me know if it works!
