How do I reset Color changed by Color.by.ARGB node .
Inside dynamo and inside Revit too
Depending on how the change has been made, you could try the Element.ResetOverridesInView node from the #clockwork package?
You look to be using Dynamo 2.0 my test was in 1.3.2
Can you expand and pin all node list boxes?
It appears your problem lies in the #clockwork node.
Can you try an extracted python script?
clr.AddReference('RevitAPI')
items = UnwrapElement(IN[0])
view = UnwrapElement(IN[1])
booleans = []
override = OverrideGraphicSettings()
for item in items:
try:
view.SetElementOverrides(item.Id, override)
booleans.append(True)
except: booleans.append(False)
OUT = (items,view,booleans)
Hi, This is not working all the time. It doesn’t respond in 3d views. And sometimes in Plan view as well. Please help
