I’m trying to find out how to change the values of a fixed set of parameter from a bunch of elements. The values vary per element. For instance, change the “Mark” and “Comments” from each selected element to “Win 1” & “Comm 1” for element 1, “Win 2” & “Comm 2” for element 2, …
I found on the forum this code block that worked fine,
<span style=“color: #309130;”>//Designscript method to write to the appropriate COBie parameter</span>
el1<<span style=“color: #2585e5;”>1</span>><<span style=“color: #2585e5;”>3</span>>.SetParameterByName(params<<span style=“color: #2585e5;”>2</span>>,vals<<span style=“color: #2585e5;”>2</span>><<span style=“color: #2585e5;”>3</span>>);
Two questions:
What does this script mean, and more particular what is the function of <1> and <2> and <3>.
Anyone knows how this can get working with the Element.SetParameterByName node? It doesn’t seems to work well in my example below. Neither with List.Map routines.
I’m pretty sure there is a good node solution for it, but I really don’t see it myself at the moment. Anyone suggestions?
Dynamo file: Multiple parameter setting
Revit Test file: Windows
Thanks a lot !
Dieter
