Hello All,
I’m trying to create a script that set a single value for at least 6 parameters. I thought the element.setparameterbyname would but it isn’t. Is there any substitute packages which is similar to element.setparameterbyname?
Hello All,
I’ll post it when I get back at the office.
here you go.
this script list all shared parameters with the word “date” in it. I try to use the element.setparameterbyname node but it only put data on one of the shared parameters.
A tip for taking pictures of your graph, zoom in until you can read a node clearly and then click the camera button. Don’t worry if you can’t see the whole graph, the camera button will take a picture of the entire thing at the zoom level you see in Dynamo.
hi,
count number of the Value should equal the count number of the element,
so even you want the same value for 6 parameter, repeat the value 6 times by using Cycle Node
oh, never heard of cycle node before. I’ll try this one out. Thanks
I solve my own problem. I have to change the lacing to cross product. Since I the parameters I want to manipulate are present on each sheet and they have the same value
