I’m working on a graph that will check a Yes/No value on my Titleblocks. Those values control our KeyPlans and turn various area on and off.
I think I’ve got everything figured out except for actually applying the values to the correct parameters on the correct families
I’ve got one list of the Titleblock families, and another of the values that should be set for each.
But it won’t set the correct values.
I assume this has something to do with Lacing, but that concept still hurts my brain.
Here’s a snip of just the lists and the nodes I’m using
The upper right is all of the Titleblocks affected. The upper left is the Parameter names. Each Titleblock has both those Parameters
The List.Map node has the correct values that should be getting applied.
In the SetParameter node, I’ve currently got Longest for Lacing, but I’ve tried all the other options, too.
Or is there an easier way? Maybe another Lisp.Map somewhere?
Thanks in advance
