I have a script that is working with no errors, but it is not outputting the correct info in the correct locations.
I am wanting to grab info from the curtain walls and send them to an Assembly Parameters. Everything seems like it is working like it should, but the info is not correct or in the correct place.
Here is the end of the script where the lists are being fed into the set parameter node. I’ll put a link to the script below.
You can see here how the info looked in Revit.
