List-lacing-levels
Hello everyone
I’m trying to set multiple parameter value to multiple elements. I tried all combination of list-level-lacing.
But not getting expected results.
Below is the same example of my problem.
Please try with sample file and give suggestions
list-lacing-level.dyn (22.8 KB)
Sample R2022.rvt (5.2 MB)
Your final lists are @L3 but you’ve not set any levels on the Set parameter node.
Try setting the final node to L2 for each input. (Click the > and set L2 for all 3 of the inputs)
@Alien
I have already tried this but not working
You might wanna try longest lacing too.
Also, just experiment with going up and down the levels.
I have almost tried everything. but i don’t understand, why its not working?
Try to simplify the problem with following methods:
Method01
It is the perfect situation to use Python, Method02:
Python Script:
list-lacing-level_V1.dyn (70.8 KB)
A line of Design Script should deliver the expected result
Revit.Element.SetParameterByName(elm<1>, pnm<1><2>, pvl<1><2>);
