Set style for CoGo Points or CoGo Point Group
Is it possible to set the Point style on Cogo Points and the default style for a specific Point group?
I have found that it’s possible to set the style as a string value but I would also like to have the possibility to select style from dropdown node but haven’t found it.
HI
ONE WAY TRY
99
nice…
will try it out.
Thanks @hosneyalaa
You could also use the Data-Shapes package to create a dropdown menu using that entire list as input.
Yes, why not. I use it already to let the user select which corridor featurelines to be used in the graph.
I saw that I wasn’t that clear in the question.
I’m able to set the style but the only way I have found to add which style to use is by typning it as a string.
In my graph I want to let the user to choose between different kind of Point label styles and Point styles and I couldn’t find a way to make it possible for Point Styles, only for Point Label Styles.
hi @patrick.ericson
can you try this
sty
That was amazing @hosneyalaa
Big thanks!!
