Is CogoPoint not a CivilObject?
Hi
I am trying to add a style to cogopoints but when i try to do so with the civil extension i get the following error:
Warning: DocumentExtensions.SetStyle expects argument type(s) (Autodesk.Civil.DynamoNodes.CivilObject, string), but was called with (Autodesk.Civil.DynamoNodes.CogoPoint, string).
No cogo points aren’t considered civil objects. But try using the CogoPointExtensions.SetStyle node in the toolkit.
Thank you for your reply
When i check under the CogoPointExtensions i do not find a note called SetStyle:
(i have civiltoolkit 1.1.9 installed)
nevermind, i had an ancient version isntalled, thanks for your help!
