Need to override property stylename error
Using the new 2025.1 updates for C3D…trying to recreate an old script I had that would convert all C3D objects to a standard style, but running into issues using the updated OTB nodes (see screenshot below). As you can see in the screenshot, I’ve tried a few different ways, but getting the same result. This seems to occur with Surfaces and Cogo Points, but Alignments work no problem when trying to map them to the new style, so hit or miss kind of situation. Ultimately, I’d like to create a script that will recognize all C3D objects in a file and convert if they exist.
Hi @CADguy82,
COGO Points are a little odd in that they aren’t actually CivilObjects. So, there is a separate node to set the style of COGO Points:
With that said, the behavior that you describe with surfaces seems strange. We will investigate!
Thanks for looking into it! Same issue applies to Gravity Parts as well (Pipes and Structures). I’m not seeing a SetStyle node specific to Pipe Networks in the latest version…
Steve
Thanks for reporting this, @CADguy82. The issue has been addressed, and you can expect the fix in the next update.
Awesome! Thank you! Any chance the next update will be available before the Dynamo Day Hackathon at AU2024? :slight_smile:
Regrettably, no. But I can help you with a workaround to get through the event if needed.
The issue with the CivilObject.SetStyle node has been fixed in Civil 3D 2025.2.
