Cogo point group by cogo points - how this should work?
could you please let me know what is your experience with this node or workflow for COGO point group creation?
There is no COGO point in my new group test1.
Node works fine for me. Do you possibly have any Raw Description Matching/Include/Exclude group properties that would prevent the points from being included in the group? Perhaps a Point style?
Also working for me (generated 16000 cogo points, one point group, and a surface from 1/4 a square kilometer of topography from Forma without issue).
I think there is a bug where the node doesn’t force the toolspace to refresh - right clicking and selecting ‘refresh’ can fix it if that is the issue, though ‘null’ has me thinking it’s something else.
Do you have cogopoints on the previous node?
@jacob.small, thank you for your answer. There is no progress.
test_COGOPointGroup.ByCogoPoints.dwg (845.7 KB)
test_COGOPointGroup.ByCogoPoints.dyn (15.8 KB)
Which Civil 3D version are you in?
Your DWG, your DYN, my results:
Perhaps an environment variable? Might be a good idea to submit a ticket to Autodesk support via the accounts portal at manage.autodesk.com.
I can see only this warning in command line “Mismatch of types. ( Point number = …”
Nesoulad typů. ( Číslo bodu = 41,42,43,44,45,46,47,48,49,50,51,52,53,54,55,56,57,58,59,60,61 )
Civil 3D 2024.4 update was solution for Civil 3D 2024.
Ah, I had this issue in one of my Civil 3D plugins:
It is only an issue when the comma is set as decimal separator in Windows settings, and only since Civil 3D 2024. On English systems there is no issue, so it is hard to reproduce.
