I know you can Add Parameters, Utilize Excel, And even Delete Shared Parameters if needed. I was wondering if there is a way to change the actual path of the Shared Parameter file specifically in the project?
This way I can extract the newly loaded Shared Parameter file into Families I may need parameters loaded into. Let me know what you think!
I don’t believe this is possible through the API. There is an OpenSharedParameterFile method, but not a corresponding ChangeSharedParameterFile method or anything similar.
This worked absolutely perfectly! Thank you so much. Now I can do a Passthrough command, to input the parameters from this file into my families.
THANK YOU!
