Is this possible. I want to change a Parametername (shared). Can i even access this Name?
It should be
OK ab Koordinationsebene
Or is there a workaround? like replace shared Parameter without distroy his values?
KR
Andreas
Actually i it is not only a family Parameter but also a Projectparameter … … hmmm, Thank you! i will test that in a detached Model!
Hi @Draxl_Andreas,
It isn’t possible to rename the project parameters associated to a shared parameters file as discussed here :
A workaround to rename the family parameters associated to a shared parameters file :
