Hi All,
Im trying to set material to floor but nothing seems to be working, see below approach.
am i missing something here?
Thanks…
Hi All,
Thanks…
We need the model you’re testing this on as there is no indication of what type of element you’re selecting.
Assuming it’s a normal floor, and that you want to assign a material to a layer of the construction, you have to select the type not the instance, then get the layer, and apply the material to that. I believe that clockwork has some nodes for that.
Thanks @erfajo
I have used a couple of scripts to do a repetitive change on 22 models, thanks for the info.
RHD-DYN-REV-RedSea_Wall_Floor Changes.dyn (97.8 KB)
