Set Default Geometry Working range
Is it possible to set it to some other value other than medium? It’s tedious to change it to Large everytime I open it since I’m working in metric.
Thanks.
Hi @Der_Jon
Isn’t you set one time and save your graph it recognizes next time large working range.
Hi @Kulkul
I’m not sure I understood what you said. Do you mean saving a file wherein I’ve already set the Geom Working range then I open that file every time?
Isn’t there any way to have the setting stored within Dynamo itself?
I mean if you set the working range and next time you open it is always set to Normal range for that file.
I had a look at DynamoSettings.xml file but didn’t found anything :frowning:
This is probably worth a post to the GitHub if we can’t find a way to do it directly. I’ll start the timer. :wink:
I see…
I’ll open an issue then.
What about using a template?
I have the tendency to save templates to the same file.
But since Github feature requests are rarely done especially in large projects such as Dynamo, I might have no choice.
They actually are very good at sliding those requests into the queue. One the ones I’ve commented on is underway.
