Geometry Working Range Error
Hi there,
What does the attached warning mean? How can I fix.
This means that you are calculating geometry outside of the limits of Dynamo’s current precision. To resolve click on settings, then geometry scaling, and select ‘Large’ as your working range.
Changing units from MM to M is also a common solution.
