Set Category Visibility Without Changing Overrides?
How can I change category visibility in a view template without changing the overrides?
I’m trying to toggle the visibility of a few categories in all my view templates. I am able to do that with my script (see below) but the process wipes out the category overrides I had previously setup in view templates.
How can I set the overrides input to none/null/don’t change?
Dynamo: set category visibility.dyn (26.6 KB)
Revit: test.rvt (800 KB)
@Bren Try using the View.SetCategoryVisibility node from the designtech package.
Please pay close attention to the circled levels & lacing or else it might not work.
That does work. Unfortunately my firm has a standard to not use any third party nodes (causes too many breaks).
Does anyone know how to collect the overrides from a view template so I can feed them right back in?
@Bren Collecting overrides doesn’t sound like a good option!
Why not do it the python way?
Only because I don’t know the python way. Would you mind sharing?
@Bren Here you go.
clr.AddReference("RevitAPI")
toList = lambda x : x if hasattr(x, '__iter__') else [x]
views = UnwrapElement(toList(IN[0]))
categories = toList(IN[1])
boolean = IN[2]
status = []
for view in views:
	for category in categories:
		try:
			view.SetCategoryHidden(ElementId(category.Id), boolean)
			stats = "Category Visibility updated for " + view.Name
		except:
			stats = "Category Visibility couldn't be updated for " + view.Name
	status.append(stats)
OUT = status
Works like a charm! Thank you so much. :slight_smile:
Dynamo: set category visibility.dyn (21.0 KB)
Okay, now to make life for complicated…
Can I use levels and lacing to feed in variable booleans?
Dynamo: set category visibility v2.dyn (21.1 KB)
Revit: test2.rvt (624 KB)
@Bren Levels & Listing won’t help you because of the way I wrote the logic.
I’ve updated the logic for you. See if that works for you now.
#Script by AmolShah
#https://forum.dynamobim.com/t/set-category-visibility-without-changing-overrides/60030/
booleans = toList(IN[2])
status = []
for i,view in enumerate(views):
	if len(categories) == len(booleans[i]):
		for category,boolean in zip(categories,booleans[i]):
			try:
			except:
		status.append("Booleans not equal to categories")
OUT = status
Amazing. Thank you again!
