Hi!
I am looking for possibility to clear chosen overrides for the chosen category in all ViewTemplates
Do you know any nodes / python codes which could be useful in that case?
Hi!
When i do it manualy i just duplicate view without details.
Than i copy the 2D-Elements fro, one to an other view.
Maybe this?
I mean to clean overrides only for chosen category, chosen column (e.g. clean projection/surface patterns and stay rest as is).
I thought also that it could be achieved by new overrides for selected options by setting empty/null values - but I am not sure if that is possible
Using python nodes I am able to set any overrides - but can I used value as None?
I tried to do this using this method but I got info that it’s only read value.
I was able to achieve removing overrides for the chosen category but unfortunately, it removed all overrides for category. Could anyone help me with that problem?
clr.AddReference('RevitAPI')
from Autodesk.Revit import DB
clr.AddReference('System')
category = UnwrapElement(IN[0])
view = UnwrapElement(IN[1])
if view.ViewTemplateId == DB.ElementId.InvalidElementId:
ovg = DB.OverrideGraphicSettings()
ovg.SetCutLineColor(DB.Color.InvalidColorValue)
#ovg.SetProjectionFillColor(DB.Color.InvalidColorValue)
#ovg.SetSurfaceBackgroundPatternColor(DB.Color.InvalidColorValue)
#ovg.SetSurfaceForegroundPatternColor(DB.Color.InvalidColorValue)
view.SetCategoryOverrides(category.Id, ovg)
# send true if successfule
OUT = True
# send False if not
OUT = False
You’re applying a new (empty) ovg on that category.
Try to get the existing ovg of the category in that view with view.GetCategoryOverrides(category.Id)
and apply your changes to it.
