Set Beam's Geometric Parameters
Does anyone knows how can I set a Geometric Position parameter of a beam in Revit using Dynamo?
I tried to use Elemente.SetParameterByName (Picture), but didn’t succeed.
It should work if you type it correctly i.e. “z Justification” with a space
Still doesn’t work!
It also takes numerical input and not a string:
Also it is an instance parameter and you’re feeding it a family type right now.
You should select all instances of that family and change their parameter.
Thanks man!
