Hello Guys,
I am using Dynamo to place all my beams into Revit and for the most part it’s working well. the issue that I’d like to clear up is the insertion point for my beams. in Revit I can change the geometric position as it’s inserted. (z and y justification) but is there a way I can manage this in Dynamo? the justification seems to change in different projects and I want to lock in a certain justification so this does not change if possible.
better yet, is there a way to change any object properties from dynamo?
Thanks,
David
@braicodavid ,
you can set those parameters using Element.Set.ParameterByName
Great thank you.
