Set beam Y and Z justification failing in Revit 2023
Hi!
I had a script that worked with revit 2021 and now with revit 2023 stopped working the node of set element parameter by name, regarding beam justification.
This is what I get for Y justification that worked before. The same thing happens with Z justification.
I believe it has something to do with the new API changes, since it worked before. If I put true or false it gives no error, but is for properties with checkboxes and not this one with 4 options.
Any help? Anyone else has had this same problem?
Thanks!
Hello @Mihdi_Caballero - as per 📢 Dynamo 2.13 - Revit 2023 Set Parameter Issue(s) - Hotfix Out Now this is now fixed in the Revit Hotfix, so please go download :partying_face:
Thank you, @solamour!
