Set parameter by name, using API
how can I set a parameter by his name using the Revit API? I actually want to modify the value to one of the parameter of my FamilyType.
(I try to code exactly what the SetParameterByName note does)
Thanks!
This was already exposed in the forum :
elements=IN[0]
parameter_names = IN[1]
values = IN[2]
for e, v in zip(elements, values):
	e.SetParameterByName(parameter_names,v)
OUT = elements
I’ve tried this one, but ‘elements’ for me are FamilyType and the error says that FamilySymbol (my family type) doesn’t have the argument SetParameterByName
*attribute
SetParameter works with elements :
If you want to SetParameter inside a family, you can use the node from Orchid Package.
Family%20SetParameter
You need to post a snippet of your code so we can investigate where the issue is coming from.
We cannot do that with your description only.
Maybe this?
|Public method|ChangeTypeId(ElementId)|Changes the type of the element.
(Inherited from Element .)
If not it might help you identify an alternative solution…
http://www.revitapidocs.com/2018/f4f2420f-bba6-dac2-9b93-4e55a58d1375.htm
Hope that’s useful…
Mark
