does anyone know the workflow for setting the project basepoint respectively the survey point?
Hi Peter,
I’m not sure if this helps, but when you want to move the survey point, you need to modify the base point and vice versa:
What did you have in mind?
Dimitar thanks again. that solves the issue.
peter
Dimitar , I’m attempting to copy your nodes but I seem to be missing something.
Note my Watch node - only showing 1 value.
What am I missing?
Lacing!
Lacing?
Right click in set Parameter node and set lacing to longest.Second Option create an extra set Parameter for each value
That’s great. Thank you for the reply and explanation.
Much appreciated.
