I have creted this in Dynamo.I want this to work so that I can select which level I will work with and then replace the value of all elements in this level. The parameter I would like to change is “magi_ov2”. I get an error in the end, is this because the parameter magi_ov2 not exist on all element?
Is there also a possibility to be able to select elements by system or all MEP elements.
What I really want to do is to select one level and then select one system or every system in this level model, change the value of the parameter magi_ov2 to another value.
