Selecting and copying a specific category from a linked model from an active view
Hey there people. Im working on a slight problem that is occupying my mind.
I ran into a problem making a script thats supposed to what above was mentioned:
( This is about taking the voids that are modelled with a volume and can be seen when isolating them in a 3D view from a MEP Planer. I as an architect gotta take them over into my modell. Usualy you can click on one and copy paste it into your model. Theres just too many of them to do it manually.)
The first issue is ( besides the active view) I cant make it select and copy the items I want in the first place.
Im using a 2022 version of synthesize and rhythm as they have some nodes that are missing in the 2025 version.
Any help will be appreciated!
Hello @poehm and welcome…seems you feed in the categori…try feed in the linked elements…
Thanks for the reply.
What packages are you using? ( Release date) I got the newest version of Rhythm and Synthesize and dont have the nodes Select.GetDocuments and LinkElement.OfCategory
get documents is from archilab, link element categori is from bimorph, not sure it will work in 25…but there should be many other nodes for that there probably could work in 25…maybe spring could work there…and be sure get document from synthezise give a link instance element
Found the issue. It was the AL.Get Documents
I needed the node from archilab.
Now all thats left is filter the items by view and hope for it to work!
Appreciate the help!
yeah or just ootb…and for doc you could use revit link document from rhythm
that one didnt work for some reason. It couldnt gather find the link in.
