Any way to get all the connected elements in Dynamo like how we can do it in the UI by hovering over one element and hitting Tab?
I created something that did that once, I think it was this one. It uses a geometrical apporach so for very large files it won’t be super quick.
Well I finally managed to code something up that does the same as hitting Tab in Revit. It checks the element for all its connected elements and does that recursively. I published the node in my package MEPover:
@T_Pover At its best
With that brilliant node, is Conduit Run Category completely useless? Anyone know of a good use for doing anything with Conduit Runs in a project?
I guess the advantage of using conduit without fittings would be that every element already has a parameter to which the run Id is assigned. Much like system names in duct or piping systems.
Easily schedulable lengths for feeders. I used conduit runs to house Feeder information and Lengths.
I used your node as shown in the picture to try selecting an entire run of conduit but the conduit was not selected in my model. Does the node only out a list of connected elements of does it actually select them too?
