I have two surface components in revit i needed to bring into the Dynamo work space. FOr some reason i brought in two nodes and selected each surface and the id numbers came up as being selected. … Yet only one surface will appear in the geometry workspace. I can not for some reason get the other surface into the workspace even though it says it is selected in dynamo. Does anyone have an reasons for why this might happen or how to resolve the issue?
You should connect the elements you’ve selected to a “Element.Geometry”, which works on objects and lists, and then hit “Run”. I’m guessing this is the solution, but if you could post an image of your graph that would be good.
