Select Text impossible
2019-01-19_19h34_51
2019-01-19_19h40_59
Hello Dynos,
Where the hell are the text elements. I don’t understand. it should work. Why they are not listed by ID?
What did I wrong? in 2.0.2.
In Revit 2016 - Dynamo 0.9. it works!
KR
Andreas
Can you share a model that reproduces this?
2019-01-19_20h25_50
…I think this is the problem… i do just a tutorial2019-01-19_20h32_43
test.dyn (3.6 KB)TEST_SELECT.rvt (340 KB)
Start Revit with English UI and report back if the problem persists. I‘m fairly certain this is a localization issue.
That was it, i did languagepack ENU and ENG. both work!
What language does it fail in?
german DEU
TextNotes are currently only usable in English language instances of Revit. There are a number of open issues that were reported for this over a year ago, like this one: https://github.com/DynamoDS/DynamoRevit/issues/1626
