Ok then try this python script, it uses this method from the RevitAPI
http://www.revitapidocs.com/2018.1/7991d0f9-e792-94b0-1170-0b8ea27e48ed.htm
edit: this should work for both lists and single elements
clr.AddReference('RevitAPI')
clr.AddReference('System')
if isinstance(IN[0],list):
element = UnwrapElement(IN[0])
element = [UnwrapElement(IN[0])]
list = []
for x in element:
points = AdaptiveComponentInstanceUtils.GetInstancePlacementPointElementRefIds(x)
list.append(points)
OUT = list
