This was really frustrating to figure out. There should be an AdaptiveComponent.SetLocations node in out-of-the-box Dynamo. Hopefully this will help others having similar problems. Kudos if anyone wants to clean up this code or try and make this work with multiple inputs.
input IN[0] = adaptive component instance
input IN[1] = list of points
clr.AddReference(‘RevitAPI’)
clr.AddReference(‘RevitNodes’)
clr.AddReference(‘System’)
from System import *
adaptComp = UnwrapElement(IN[0])
pnts = AdaptiveComponentInstanceUtils.GetInstancePlacementPointElementRefIds(adaptComp)
for i in range(len(IN[1])):
doc.GetElement(pnts[i]).Position = IN[1][i].ToXyz()
OUT = 0
