Hello everyone,
I have to select several points from a surface in Revit, and then create a geometry from them.
I’m using the springs node SelectFaces+, but I have to pick all of them at once without preview of the ones that I have just picked.
Is there any way to visualize the point before selecting the next one? It is really hard to select each one without the reference from the previous one.
Thanks, Álvaro
Here is a workaround.
draw temporary model lines that makes points as intersects with faces, and use Intersect node after select all of them at once.(of course u have to separate lines and surface)
Here is a workaround using transient geometry and Analysis namespace (Analysis Visualization),
import sys
import math
import System
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB.Analysis import *
from Autodesk.Revit.UI.Selection import *
pf_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.ProgramFilesX86)
sys.path.append(pf_path + '\\IronPython 2.7\\Lib')
def decoCreateAvfDisplayStyle2(func):
def wrapper(*args, **kwargs):
view = args[0]
tg = TransactionGroup(doc, func.__name__)
tg.Start()
filterP = System.Predicate[System.Object](lambda x : x.Name == "Paint_Preview")
analysisDisplayStyle = List[Element](FilteredElementCollector(doc).OfClass(AnalysisDisplayStyle).ToElements()).Find(filterP)
if view.AnalysisDisplayStyleId == ElementId.InvalidElementId or analysisDisplayStyle is None :
t = Transaction(doc, "Paint_Preview")
t.Start()
coloredSurfaceSettings = AnalysisDisplayColoredSurfaceSettings()
coloredSurfaceSettings.ShowGridLines = False
colorSettings = AnalysisDisplayColorSettings()
legendSettings = AnalysisDisplayLegendSettings()
legendSettings.ShowLegend = False
analysisDisplayStyle = AnalysisDisplayStyle.CreateAnalysisDisplayStyle( doc, "Paint_Preview", coloredSurfaceSettings, colorSettings, legendSettings )
view.AnalysisDisplayStyleId = analysisDisplayStyle.Id
t.Commit()
# function Wrapp
ret = func(*args, **kwargs)
tg.RollBack()
tg.Dispose()
return ret
return wrapper
def createSphere(center):
radius = 0.15 # decimal feet
frame = Frame(center, XYZ.BasisX, XYZ.BasisY, XYZ.BasisZ)
arc = Arc.Create( center - radius * XYZ.BasisZ, center + radius * XYZ.BasisZ, center + radius * XYZ.BasisX )
line = Line.CreateBound(arc.GetEndPoint( 1 ), arc.GetEndPoint( 0 ) )
halfCircle = CurveLoop()
halfCircle.Append( arc )
halfCircle.Append( line )
sphere = GeometryCreationUtilities.CreateRevolvedGeometry(frame, List[CurveLoop]([halfCircle ]) , 0, 2 * math.pi)
return sphere
@decoCreateAvfDisplayStyle2
def surfaceSelection(view):
"""Pick points on the face with preview with AVF"""
sfm = SpatialFieldManager.GetSpatialFieldManager(doc.ActiveView)
if sfm is None:
sfm = SpatialFieldManager.CreateSpatialFieldManager(doc.ActiveView, 1)
sfm.Clear()
resultSchema = AnalysisResultSchema("Schema Name" , "Preview_Selection")
schemaIndex = sfm.RegisterResult(resultSchema)
outSurf = []
flag = True
error = None
outgpoints = []
TaskDialog.Show("Selection", "Select points on face, tap Esc to Finish")
while flag:
try:
reference = uidoc.Selection.PickObject(ObjectType.Face, "Select points on face, tap Esc to Finish")
selectface = doc.GetElement(reference).GetGeometryObjectFromReference(reference)
outgpoints.append(reference.GlobalPoint.ToPoint() )
outSurf.extend(selectface.ToProtoType())
sphere = createSphere(reference.GlobalPoint)
for face in sphere.Faces:
idx = sfm.AddSpatialFieldPrimitive(face, Transform.Identity)
uvPts = List[UV]()
bb = face.GetBoundingBox()
uvPts.Add(bb.Min)
pnts = FieldDomainPointsByUV(uvPts)
doubleList = List[System.Double]([10.0])
vals = FieldValues(List[ValueAtPoint]([ValueAtPoint(doubleList)]))
sfm.UpdateSpatialFieldPrimitive(idx, pnts, vals, schemaIndex)
except :
import traceback
error = traceback.format_exc()
flag = False
break
sfm.Clear()
return outSurf, outgpoints, error
view = doc.ActiveView
outSurf, gpoints, error = surfaceSelection(view)
OUT = outSurf, gpoints
*Note: *
currently, this code is not compatible with CPython Engine due to a bug with math Operator overloads in PythonNet (seems to be corrected on the next version of the PythonNet package)
Thanks so much, this is exactly what I was looking!
