How can I select multiple faces from linked file in Revit?
Springs has a node Springs.Select LinkedFace, but it only selects one face.
This is the python code for the node:
Copyright© 2017, Dimitar Venkov
@5devene, dimitar.ven@gmail.com
www.badmonkeys.net
clr.AddReference(“RevitAPIUI”)
from Autodesk.Revit.UI import *clr.AddReference(“RevitServices”)
uidoc=DocumentManager.Instance.CurrentUIApplication.ActiveUIDocumentclr.AddReference(“RevitNodes”)
clr.ImportExtensions(Revit.GeometryConversion)clr.AddReference(“RevitAPI”)
from Autodesk.Revit.DB import RevitLinkInstance, FamilyInstancedef output1(x):
if len(x) == 1: return x[0]
else : return xsel1 = uidoc.Selection
ot1 = Selection.ObjectType.Element
ot2 = Selection.ObjectType.PointOnElement
li_ref = sel1.PickObject(ot1, “Select a link instance first.”)
link1 = doc.GetElement(li_ref.ElementId)
if isinstance(link1, RevitLinkInstance):
tf1 = link1.GetTotalTransform()
face_ref = sel1.PickObject(ot2, “Pick a face.”)
linkDoc = link1.GetLinkDocument()
el1 = linkDoc.GetElement(face_ref.LinkedElementId)
face_ref2 = face_ref.CreateReferenceInLink()
sf0 = el1.GetGeometryObjectFromReference(face_ref2)
if isinstance(el1, FamilyInstance):
tf1 *= el1.GetTotalTransform()
sf1 = sf0.Convert(face_ref2, tf1.ToCoordinateSystem(True) )
for s in sf1:
s.Tags.AddTag(“RevitFaceReference”, face_ref)
OUT = output1(sf1), face_ref.GlobalPoint.ToPoint(True)
OUT = “Failed to pick a link instance.”, None
