I made this:
Now I would connect output with a 3d views with the same name of selection in the drop down menu, it is possibile?
Have you tried using the newer “UI.MultipleInputForm ++” node instead?
Alternatively, if you just need a single drop-down and nothing else, you could also try the “List.DropDown” from spring nodes :
With a filter after archi-lab.net node, the first procedure is perfect for me. Thank you!
