Select Object cad text by System.Linq
HI ALL
HI @c.poupin
Please Help
How to choose TEXTS from Autocad drawing by System.Linq
selcet Object cad text by System.Linq does not work
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
editor = adoc.Editor
 # Add DesignScript references
clr.AddReference("System.Core")
import System
clr.ImportExtensions(System.Linq)
from System.Linq import Enumerable
# Enable Python support and load DesignScript library
from System.Collections.Generic import Dictionary
def get_text():
	textProps = []
	obj=[]
	handles = []
	errorReport = None
	global adoc
	with adoc.LockDocument():
		with adoc.Database as db:
				bt = t.GetObject(db.BlockTableId, OpenMode.ForWrite)
				btr = t.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite)
				btrlq = btr.Cast[ObjectId ]().ToArray()
				btraa = btr.Cast[ObjectId ]().Select(id >= t.GetObject(id, OpenMode.ForWrite))
				t.Commit()
	if errorReport == None:
		return btrlq
		return btrlq
OUT = get_text()
I can choose it with this code
import sys
import System
def get_text():
	textProps = []
	obj=[]
	handles = []
	errorReport = None
	global adoc
				for oid in btr:
				    bl = t.GetObject(oid, OpenMode.ForRead)
				    if isinstance(bl,DBText):
				       handles.append(str(bl.Handle))
				t.Commit()
		return handles
		return handles
OUT = get_text()
There is an example with c#
 var modelSpace = (BlockTableRecord)tr.GetObject(
                    SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForWrite);
                // get all curve entities in model space
                var curveClass = RXObject.GetClass(typeof(DBText));
                var curves = modelSpace
                    .Cast<ObjectId>()
                    .Where(id => id.ObjectClass.IsDerivedFrom(curveClass))
                    .Select(id => (Curve)tr.GetObject(id, OpenMode.ForRead))
                    .ToArray();
Thanks in advance for any help
Uploading: CCCC.dwg…
linq t.dyn (9.6 KB)
Hello @hosneyalaa
an example with Autocad PythonShell (I do not have Civil3D)
import sys
import System
import System
from System.Linq import *
pf_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.ProgramFilesX86)
sys.path.append(pf_path + '\\IronPython 2.7\\Lib')
import os
import math
clr.AddReference('acmgd')
clr.AddReference('acdbmgd')
clr.AddReference('accoremgd')
ed = doc.Editor
db = doc.Database
# Write Code Below
all_blkName = []
with doc.LockDocument():
	with doc.Database as db:
			bt = t.GetObject(db.BlockTableId,OpenMode.ForRead)
			btr  = t.GetObject(bt[BlockTableRecord.ModelSpace],OpenMode.ForRead)
			print(btr.GetType())
			btrlq = btr.Cast[ObjectId]().ToList()
			print(btrlq.GetType())
			#print(btrlq.Count)
			btraa = btrlq.Select(lambda id : t.GetObject(id, OpenMode.ForWrite))
			print(btraa)
			for obj in btraa:
				if isinstance(obj,MText):
					print(str(obj.Handle))
			t.Commit()
Hi @hosneyalaa
You can just change your line to:
btraa = btrlq.Where(lambda id : id.ObjectClass.IsDerivedFrom(RXClass.GetClass(DBText)))
@Kulkul @c.poupin thank you
Is it possible to get the string of each text
Thanks :pray:
Yep!
Thanks @Kulkul
I’m sorry I’m away from the computer
Is this code correct to get the string depending on what you shared
btrstr = btraa.Where(lambda id : id.t.GetObject(id, OpenMode.ForRead).textstring)
