How Combine Python Script with SelectObjects Node from Civil3D
Hello, I`m new ussing the Autocad and Civil 3D API and I would like to combine a part of a python code to get the area of a group of surfaces (wich are not TIN Surface) with the Node SelectObejcts.
In the image, I have two Python nodes, The first one (Python Script(01)) is to select the elements in the drawing space and the second one (Python Script(02)) is to get the area from the selection group, I think the problem could be the ObjectId.
if someone can help me, I really appreciate
Let the files that I used below
PythonScript(01)
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
dataEnteringNode = IN
Ids1 = []
Areas = []
editor = adoc.Editor
with adoc.LockDocument():
    with adoc.Database as db:
            #Selection Elements in Drawing Space
            Seleccion = editor.GetSelection()
            if Seleccion.Status == PromptStatus.OK:
                #Get into a variable the objects in slection
                Elements = Seleccion.Value
            # Commit before end transaction
            #t.Commit()
            pass
OUT = Elements
PythonScript(02)
import sys
Ids1 = []
Areas = []
Layers = []
Surface_Types = ["Autodesk.AutoCAD.DatabaseServices.Surface",
"Autodesk.AutoCAD.DatabaseServices.LoftedSurface",
"Autodesk.AutoCAD.DatabaseServices.PlaneSurface",
"Autodesk.AutoCAD.DatabaseServices.SweptSurface",
"Autodesk.AutoCAD.DatabaseServices.ExtrudedSurface"]
            Elementos = IN[0]
            for elemento in Elementos:
                Ids1.append(t.GetObject(elemento.ObjectId,OpenMode.ForRead))
            for i in Ids1:
                if str((i.GetType())) in Surface_Types:
                    Areas.append(i.GetArea())
                    Layers.append(i.Layer)
                    Areas.append(None)
            #t.Commit()
            pass
OUT = zip(Areas,Layers)
Get_Surface_Area_Prototype.dyn (13.7 KB)
Test_01.dwg (918.0 KB)
Hi
Ids1.append(t.GetObject(elemento.InternalObjectId,OpenMode.ForRead))
Looking at this please
Thank you so much @hosneyalaa, it works perfectly
