Hi … In a dynamo graph, I need to select an object that is within a block reference in model space, also referred to as a nested object (referene: Express Tools > Copy nested object).
Havent found it yet …
Thanks for your patience.
Is this python on the right track? No need for a transaction … right?
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
dataEnteringNode = IN
editor = adoc.Editor
rs = editor.GetNestedEntity('\nSelect nested entity: ')
objIds = rs.GetContainers()
OUT = objIds
It almost worked!!! No errors … no civil 3d crash…
Hi
Try you write code into this code
You have knowledge of C# write a program on c#
Then converted it into a python
import sys
# Add DesignScript references
clr.AddReference("System.Core")
import System
clr.ImportExtensions(System.Linq)
from System.Linq import Enumerable
# Enable Python support and load DesignScript library
from System.Collections.Generic import Dictionary
def get_text():
textProps = []
obj=[]
handles = []
errorReport = None
global adoc
with adoc.LockDocument():
with adoc.Database as db:
bt = t.GetObject(db.BlockTableId, OpenMode.ForWrite)
btr = t.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite)
#btrlq = btr.Cast[ObjectId ]().ToArray()
#btraa = btr.Cast[ObjectId ]().Select(id >= t.GetObject(id, OpenMode.ForWrite))
t.Commit()
if errorReport == None:
return btrlq
return errorReport
OUT = get_text()
oops … huge aplogy. I didnt explain clearly. I need a node that lets the user select a single object in the drawing view. The drawing object is expected to be a nested object - one that is within a block. On selecting, the output needs to be the nested object details - not the block referenced details. You can get the nexted object using Editor.GetNestedeEntity. This is probabanly already included in one of the packages, like the Civil 3D Toolkit. For now … I will try to code with python. I am not sure how to get it right though. Editor.GetNestedEntity works with Automatic mode. In my graph I need it in manual mode, to let the user select the nested object before running the graph.
Thanks for responding. I was just unclear with the need this time round.
Hi Anton,
Is it possible to further filter the nested objects by layer? I have a drawing where they are all solids nested but all are on different layers.
You probably can request the layer name with the Object.Layer node. The result of that list can be used to filter, for example with the FilterByBoolMask.
Great thanks
