GetObject() method not working as intended
Hi! I’m trying to create a simple Python script that enables the user to select a polyline in the current drawing and get its object by using its ID to split it later with dynamo functions.
The only problem is that the GetObject method, both called from the ID and the Transaction, isn’t working as intended and it returns an error.
Am I missing something here? Tried recreating a bunch of examples of this method alone from this forum and none of them seemed to work.
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
dataEnteringNode = IN
editor = adoc.Editor
def SelectObject():
    promptSelectionOptions = PromptSelectionOptions()
    promptSelectionOptions.SingleOnly = True
    promptSelectionOptions.MessageForAdding = "Selecione a Polyline"
    obj = editor.GetSelection(promptSelectionOptions)
    objId = obj.Value.GetObjectIds()
    return objId
with adoc.LockDocument():
    with adoc.Database as db:
            objId = SelectObject()
            output = objId.GetObject(OpenMode.ForRead)
            # Commit before end transaction
            t.Commit()
            pass
OUT = output
Why not use the DataShape ui for that?
Didn’t know it had selection tools, only knew about inputs. This might be the way for now. Thank you very much for the hint!
Anyway it would be great to know what’s wrong with this method in case I need to use it in the future
Solved it! The method GetObjectIds() is returning an array, so in order to run the method GetObject(), I had to specify the first element of the array.
In case anyone has the same problem something like this code below should work:
import sys
def SelectObject():
    return objId
            output = objId
            output = t.GetObject(objId[0],OpenMode.ForRead)
            t.Commit()
            pass
OUT = output
