import sys
sys.path.append('C:\\Program Files (x86)\\IronPython 2.7\\Lib')
clr.AddReference("System.Core")
clr.AddReference("RevitAPI")
import System
from System.Linq import Enumerable
from Autodesk.Revit.Creation import *
from Revit import Elements
app = DocumentManager.Instance.CurrentUIApplication.Application
def toList(input):
if isinstance(input, list) == False:
return [input]
return input
# Unwrap the input element
importInstance = UnwrapElement(IN[0])
# Initialize an empty list to store the layer names
layers = []
# Initialize empty lists to store the information
layer_names = []
line_types = []
curves = []
text_values = []
# Check if the input element is a CAD import instance
if isinstance(importInstance, ImportInstance):
# Collect all layers from the CAD import instance
for subcategory in importInstance.Category.SubCategories:
layers.append(subcategory.Name)
# Get the geometry of the import instance
import_instance_geometry = importInstance.get_Geometry(Options())
# Iterate over the geometry and extract information
for geometry_object in import_instance_geometry:
if isinstance(geometry_object, GeometryInstance):
symbol_geometry = geometry_object.GetSymbolGeometry()
for curve in symbol_geometry:
curves.append(curve)
elif isinstance(geometry_object, Line):
line_types.append(geometry_object.LineStyle.Name)
elif isinstance(geometry_object, TextElement):
text_values.append(geometry_object.Text)
# Handle the case when the input element is not a CAD import instance
OUT = "Input is not a CAD import instance."
OUT = layers, line_types, curves, text_values
@ericke1 ,
it works …
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
def toList(input):
return [input]
return input
#Unwrap the input element
#Initialize an empty list to store the layer names
layers = []
#Initialize empty lists to store the information
layer_names = []
line_types = []
curves = []
text_values = []
#Check if the input element is a CAD import instance
KR
Andreas
but actually no work Text_value still show empty list
it is not possible to get the text value from a ImportInstance (dwg link) by analyzing its geometry
you can use the BimorphNodes package (that uses another process)
Hey,
LinkDWG also has a few nodes that you can dig around in to see the code… It’s using COM objects and you need to have AutoCAD open to get them.
Hope that is of interest…
I don’t want to load that node to every pc so I decide to writing code by my self but thank for this suggestion
Revit has the AcDbMgd.dll library available.
You could side load the DWG file and scrape for text objects using the Autocad API
clr.AddReference("AcDbMgd")
# get DWG path example
dwgpath = IN[0]
with Database(False, True) as db:
db.ReadDwgFile(dwgpath, FileShare.ReadWrite, False, "")
# Do AutoCAD API stuff here
# Commit changes
t.Commit()
Thank you very much for your comment, I have ideas that you could use, but I still don’t understand very well how the code could interact with Revit using the code in PYTHON SCRIPT. Could you share a little more about it, since the “AcDbMgd” library to begin with I wouldn’t know how to obtain said library
The AcDbMgd.dll file is installed with Revit - although not officially documented I believe it is used to import/export DWGs
I have used it in the past to make changes to exported DWGs to comply with client requirements by sideloading and making changes using Revit data
Please note that when using it with Dynamo and python it can be incredibly temperamental
That DLL is a portion of the AutoCAD API, so documentation there of would be in the AutoCAD API documentation. However as only a portion of the necessary DLLs are provided you are somewhat limited in their access and capability before we take Python’s limitations into accountz
In hindsight there is a VERY good reason Python based custom nodes never caught on in Dynamo for Civil 3D - Python access to the API is too limited by the great many ties into NET methods which don’t have a proper wrapper in Python. Doesn’t mean you can’t accomplish it, but that it is much harder and more apt to break to pieces on any given update to the house of cards that you’re relying on. BetweenNET, Revit, Revit API, AutoCAD API, Dynamo, Python, Dynamo’s Python engine, and any/all customizations even not utilized to any of the above (even if not used by your script) can cause things to break. Moving to C# would be better if you’re up for it, but that’s a bigger lift and there is usually a better path forward for scaled automations (i.e. batch process the file using regular AutoCAD, or move to APS or other tools).
Totally agree here
The AutoCAD API inherently feels unstable when using Dynamo and python - some days it just doesn’t like the way the wind is blowing and decides to throw exceptions (and this is on Civil3d not just Revit)
And the C# equivalent is somehow insanely stable and performant… It’s almost like code likes to be run in it’s intended environment or something.
