I am trying to get the rooms of elevation views by using the location point of each view. However, the Select.GetRoomAtPoint node is not working. Does anyone else have issues with this node?
Revit 2020
Dynamo 2.3
Archi-lab package 2020.23.13
I’m not familiar with the node in that package but MEPover have a ‘RoomAtPoint’ node that you could try instead and see if you have better luck.
I’d suggest pinning the drop-down previews on the nodes leading up to it - it’s hard to determine what might be wrong if we can’t see what the inputs/outputs of nodes are.
Thank you for your reply and suggestion Hamish. I’ll give this the MEPower package a try!
